Monitoring, Management & Location Tracking
What can be the max floor plan size loaded in VisualRF?
Question: What can be the max floor plan size loaded in VisualRF?
Answer : 2500x2500 feet is the largest we recommend in VisualRF. You can go larger but it is not recommended. At 4,000x 3000 meters the grid cell size will be huge and the best case location accuracy will be bad. Not to mention that the backend will have a huge amount of work to do and start to run out of resources.
Version history
Revision #:
1 of 1
Last update:
‎06-27-2014 04:40 PM
Labels (1)
Contributors
