Monitoring, Management & Location Tracking
What does 00:00:00:00:00:00 represent in AppRF --> WLAN?
MVP
MVP
Q:
When we navigate to AppRF --> WLANs on Airwave we can see one of the WLANs represented as 00:00:00:00:00:00 . What does this mean?
A:
00:00:00:00:00:00 in the WLAN widget in the AppRF dashboard represents the wired traffic. The reason why this field is represented as 00:00:00:00:00:00 is because, for the wired clients BSSID field would have the value as 00:00:00:00:00:00.
Version history
Revision #:
2 of 2
Last update:
‎02-27-2017 07:06 AM
Updated by:
Labels (1)
Contributors
