Monitoring, Management & Location Tracking
When we enable AMON between controller and AirWave, how often does controller update by AMON (PAPI)? Can we configure this interval ?
Environment  :  Airwave gets data from the controller via AMON
The controller update by AMON to Airwave is not a configurable value.
There's 2 main types of messages: STATE and STAT
STATE messages are processed like the normal trap messages that Airwave process.
STAT messages come in update packets with intervals of a minute.
Behavior of these messages from the Controller to Airwave are not configurable.  From an AirWave point of view, the messages come in and are put into a queue which is processed regularly based on the client data poll period.
The client data poll period is configurable in AMP with a minimum of 5 minutes at the group level.
Version history
Revision #:
1 of 1
Last update:
‎07-10-2014 03:25 PM
Updated by:
Labels (1)
