Monitoring, Management & Location Tracking
Why am I getting so many Desired mismatches on my Symbol AP / controller ?
Large number of Desired mismatches
What's going on ?
Symbol configs tend to be very large. Sometimes the telnet session times out before AMP gets
the entire config; other times entire sections in the middle of the config don't come
through. A large number of Desired mismatches would be consistent with this behavior.
Check the /var/log/telnet_cmds log against the template and the device's actual config to see
if sections of the config are not coming through.
The near term solution is to keep trying to audit the device until the entire config comes
through. We understand that this may not be a practical solution.
We'll have better support for Symbol configs in 7.1 which we're expecting to be out sometime during Q3.
Version history
Revision #:
1 of 1
Last update:
‎06-30-2014 11:45 PM
Updated by:
