Why does Group created on Master console does not show any device count mapped on the managed Amp?
When a group is created on master console it will be pushed to all the managed amp which is added with Manage group configuration enabled. The Group pushed to the managed amp will be created as Global group and you can create subscriber groups for the global group to which you will add the device into since we cannot add any devices into global group directly.
Hence there is no device added to the global group, on the master console it does not show any device count for the groups that are created on master console.
