Monitoring, Management & Location Tracking
Why does rabbitmq msg_store_transient files stored in disk?
MVP
MVP
Q:
A:
Airwave stores the rabbitmq msg_store_transient files stored in disk at /var/lib/rabbitmq/mnesia/rabbit@localhost/ directory.
Rabbit server starts to persist messages to disk when can no longer hold the backlog in physical memory. This will lead to server performance issue considering the physical memory is completely utilized. It is always recommended to keep the server hardware upgraded as per the sizing information to avoid such performance issue.
Version history
Revision #:
4 of 4
Last update:
‎05-07-2015 08:17 PM
Updated by:
Labels (1)
Contributors
