Monitoring, Management & Location Tracking
Why some APs does not display the correct hardware model on Airwave
MVP
MVP
Q:
Why does some of the CISCO APs shows as Aironet 1000 and Motorola APs AP-100 even though their model is different
A:
Airwave will pick up the model for CISCO APs as Aironet 1000 and Motorola APs as AP-100 when the model of the APs are not supported on Airwave. When Airwave receives the AP model from these devices with a model not listed on Airwave's catalog it will by default mark the CISCO APs as Aironet 1000 and Motorola APs as AP-100.
Version history
Revision #:
2 of 2
Last update:
‎01-10-2017 08:21 AM
Updated by:
Labels (1)
Contributors
