Monitoring, Management & Location Tracking
Why we are not seeing latest upgrade patch notifications on home page though server is online
MVP
MVP
Q:
Why we are not seeing latest upgrade package available notification on Home page though server is online?
A:
Step 1: Check whether awmsnews is enabled in seas_config table
[root@localhost mercury]# dbc "select awmsnews_enabled from seas_config";
 awmsnews_enabled
                1
(1 row)
if it is set to zero(not enabled) try run below command to enable
[root@localhost mercury]# dbc "update seas_config set awmsnews_enabled = 1";
UPDATE 1
Step 2: Check the status of awmsnews, if it set to 2 ,it means the notification is hide.
[root@localhost mercury]# dbc "select awmsnews_status from seas_config";
 awmsnews_status
               2
(1 row)
Set status to 1 to popup the notification on home page
[root@localhost mercury]# dbc "update seas_config set awmsnews_status = 1";
UPDATE 1
Version history
Revision #:
2 of 2
Last update:
‎03-29-2017 03:21 AM
Updated by:
Labels (1)
Contributors
