Monitoring, Management & Location Tracking
With Proxim APs: How to configure one SSID for RADIUS MAC Auth, one Open
The bottom line is that with respect to Proxim APs, AMP *cannot* configure one SSID for MAC authentication using a RADIUS server and another SSID to be open; all SSIDs will end up being configured one way or the other.
The workaround is to go into the devices and configure them directly, then create a customized audit in AMP to ignore the items causing a mismatch --click on link in Configuration column for device (e.g. "Mismatch") to take you to the Audit page for that device; Customize; check boxes of items to be ignored; Save; subsequent page: Apply Changes Now).
Version history
Revision #:
1 of 1
Last update:
‎06-09-2014 09:27 AM
Updated by:
Labels (1)
Contributors
