Monitoring, Management & Location Tracking
benign /var/log/pgsql message from syslog processing (Copy device_event takes 60000 ms)
In AirWave 7.3 a new message will appear regularly in the pgsql log located in /var/log/
May 25 04:05:55 fluorine postgres[8294]: [1068-1] LOG: 00000: duration: 59995.884 ms statement:
May 25 04:05:55 fluorine postgres[8294]: [1068-2] COPY device_event (
May 25 04:05:55 fluorine postgres[8294]: [1068-3] source_device_id,
May 25 04:05:55 fluorine postgres[8294]: [1068-4] ap_id,
May 25 04:05:55 fluorine postgres[8294]: [1068-5] client_mac,
May 25 04:05:55 fluorine postgres[8294]: [1068-6] severity,
May 25 04:05:55 fluorine postgres[8294]: [1068-7] facility,
May 25 04:05:55 fluorine postgres[8294]: [1068-8] category,
May 25 04:05:55 fluorine postgres[8294]: [1068-9] type,
May 25 04:05:55 fluorine postgres[8294]: [1068-10] message
May 25 04:05:55 fluorine postgres[8294]: [1068-11] )
May 25 04:05:55 fluorine postgres[8294]: [1068-12] from STDIN with CSV null as 'null'
May 25 04:05:55 fluorine postgres[8294]: [1068-13]
May 25 04:05:55 fluorine postgres[8294]: [1068-14] LOCATION: exec_simple_query, postgres.c:1135
This message will be periodic (every minute) and is part of the syslog feature and can be safely ignored. It should not cause any undue log inflation and is part of normal AMP operation. This message may be easily confused with actual warning messages regarding slow pgsql performance (duration exceeding 2000 ms) so please keep this in mind.
Version history
Revision #:
1 of 1
Last update:
‎06-25-2014 03:29 PM
Updated by:
Labels (1)
Contributors
