scriptlet failed message during AMP upgrade
PROBLEM:
Upgrade fails with an error like this:
"scriptlet failed, exit status 255"
SOLUTION:
This happens occasionally when selinux is set to permissive mode. You can resolve the problem by disabling selinux with the following procedure:
1. Open /etc/selinux/config with the pico text editor:
# pico /etc/selinux/config
and change
SELINUX=permissive
to
SELINUX=disabled
2. Run a make:
# root; make
That usually resolves the problem. Sometimes, because selinux is a kernel module, you have to reboot the system and repeat the make process:
# reboot
# root; make
Version history
Revision #:
1 of 1
Last update:
‎06-06-2014 04:04 PM
Updated by:
Labels (1)
Contributors
