Monitoring, Management & Location Tracking
start_amp_upgrade fails with "Upgrade script found in local cache"
Problem: Occasionally our upgrade script can fail with this error:
" Upgrade script found in local cache.
Upgrade package AMP-6.3.0-cvs.tar.gz was not found in local cache.
/usr/local/airwave/bin/start_amp_upgrade: line 244: /root/AMP-6.3.0-amp_upgrade: Permission denied
Goodbye"
Solution: Run this command:
# rm -rf /root/AMP-*amp_upgrade
then run start_amp_upgrade again, being sure to use valid credentials.
Version history
Revision #:
1 of 1
Last update:
‎06-10-2014 08:20 PM
Updated by:
Contributors
