tcpdump wireshark example
Below are some examples of tcpdump commands for capturing packets that can be opened with Wireshark or Ethereal:
To get all traffic between the AMP and any one host:
# tcpdump -s0 -w <FILEPATH> host <IP_ADDRESS>
For all traffic on a specific port:
# tcpdump -s0 -w <FILEPATH> port <PORT_NUMBER>
For a specific port AND a specific remote device
# tcpdump -s0 -w <FILEPATH> host <IP_ADDRESS> && port <PORT_NUMBER>
As a specific example, if I wanted to capture all the snmp traffic on port 161 between my AMP and a controller at, and I wanted that traffic in a Wireshark-readable file at /tmp/controller_snmp.dmp, I would do this:
# tcpdump -s0 -w /tmp/controller_snmp.dmp host && port 161
For more detailed information consult the man pages for tcpdump
#man tcpdump
A copy of Wireshark can be downloaded from:
Version history
Revision #:
1 of 1
Last update:
‎06-10-2014 03:05 PM
Updated by:
