Monitoring, Management & Location Tracking
unable to delete SSID proifle of VC from instant config
MVP
MVP
Q:
Unable to delete SSID proifle of VC from instant config
When trying to remove a Network profile on a IAP cluster in Airwave its prompting below error
 The error im getting is :
 Cannot delete SSID which is currently being referenced in the Network Assignments section.
A:
Based on the error message it looks like we have mapped the SSID profile in network assignment section. We need to uncheck before proceeding for deleting the profile.
Navigate to Groups>Instant config> Networks section, down the page we  will see below hyper link option, click on this it will take you to Network Assingment Section.
Assign wired profiles to interfaces
from drop down list uncheck the profile which we are trying to delete and try deleting again.
Version history
Revision #:
2 of 2
Last update:
‎03-29-2017 02:09 AM
Updated by:
Labels (1)
Contributors
