write mem after IOS config push
AMP has an optional "use write mem" feature for IOS APs. By default, the control to enable it will not show up in the AMP GUI. To enable the setting,
[root@amp ~]# db
airwave=> update seas_config set allow_write_mem = 1;
UPDATE 1
airwave=> \q
Once you've done that, AMP will use this process to configure the APs:
1. Build a config file and save it as the startup-config
2. Copy startup-config to running-config
3. Copy running-config startup-config
Version history
Revision #:
1 of 1
Last update:
‎06-06-2014 02:46 PM
Updated by:
Labels (1)
Contributors
