Network Management
djv
Occasional Contributor I
2 out 45 sites are not showing any clients in Airwave 8.2
I have 45 school sites with 7030, 7010, 7205 and 7210 controllers all on 6.4.3.4.
Of those 45 only 2 sites will not show any clients in Airwave.
Has anyone ever seen this before.
Thank you
Re: 2 out 45 sites are not showing any clients in Airwave 8.2
Can you see the controller at those sites as Up in Airwave?
djv
HI Colin,
Thank you for respnding.
I placed a trouble call in with support,
 They found that it was a user error...mine.
After replacing 45 3200 and 3400 controllers with 7030 and 7010
controllers, I forgot to to add the Airwave server config under, Configuration/General/Airwave server.
