Network Management
3600 Controllers and Airwave
  • 1.  3600 Controllers and Airwave
    Posted May 11, 2012 12:55 PM
    Starting to test AP-105's as Remote AP's to cover some remote offices and seem to be able to see one RAP-105 in Airwave but not the second RAP-105 I am using.  Both are up according to the Controller but Airwave only reports and see's one of them.  Airwave is on a seperate subnet than the controllers but this is the first issue I have had with it.  Any suggestions?
    AC
    #3600
  • 2.  RE: 3600 Controllers and Airwave
    Posted May 11, 2012 07:35 PM
    Make sure your RAP is not in the "New Devices" or Ignored Devices list in Airwave.
  • 3.  RE: 3600 Controllers and Airwave
    Posted May 14, 2012 09:10 AM
    Thank you.  I had ignored that AP since I was testing with it a couple weeks ago.
