Network Management
Frequent Contributor II
AMON and UCC
What additional functionality does Airwave provide when AMON is enabled on the controller versus standard SNMP monitoring. Our customer has Lync integration enabled on the controllers in addition.
Re: AMON and UCC
AMON is required for UCC reporting as well as AppRF data.
Sent from Nine
Tim Cappalli | Aruba Security
Re: AMON and UCC
Thanks Tim, the controller has been added to Airwave but when I run the command - show mgmt-servers there is nothing listed there. If I specify Airwave as a management server will this simply enable the sending of AMON messages or will the enable Airwave management of the device which the customer does not want to implement. There is precious little information in the user guide regarding this.
Re: AMON and UCC
Yes you should configure AirWave as a mgmt-server type amp
Sent from Nine
Re: AMON and UCC
OK, I need to be sure that this won't put the controller into managed mode by Airwave if I configure this on the controller.
Re: AMON and UCC
It will not.
Sent from Nine
Re: AMON and UCC
MDRF,
AMON is a one-way protocol that just sends traffic from the controller to Airwave.  It does not require management mode.  Please see the Airwave Aruba Controller setup document here:  https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=14097
 http://community.arubanetworks.com/t5/Community-Tribal-Knowledge-Base/Why-you-should-always-enable-AMON-on-your-Aruba-Controller-when/ta-p/72104
Colin Joseph
Aruba Customer Engineering
Re: AMON and UCC
OK, thanks Tim.
Re: AMON and UCC
One more thing - do I just run the command - mgmt-server type amp primary-server x.x.x.x or do I need to create a mgmt-server profile and apply it somewhere?
Re: AMON and UCC
You can use the default-amp profile. Just ensure that UCC is enabled in the profile.
Sent from Nine
