Network Management
Contributor I
AMON prefered over SNMP issues
I needed to disable Prefer AMON over SNMP so some wired usersnames would show up in Airwave. After I did so, the usernames showed up but I noticed a significant drop in users on my clients graph. I sorted by SSID and you can see that only 1 SSID took a hit. The bottom line is the SSID that lost clients as soon as i turned prefer amon off.
Im having issues figureing out why this is. Any insight?
Re: AMON prefered over SNMP issues
Do not turn on "preferred Amon".  There is a bug with counting users in some versions of Airwave.  Just turn it off and still send an Amon feed and you should be okay.
Contributor I
Well I looked at the controller and I have more than 150 clients on that last SSID. So why is it reporting such a low number?
We have bug DE22391 in Airwave where RAP wired clients not showing up when we enable prefer AMON over SNMP setting. This issue will be fixed in AMP 8.2.4 and ETA is mid of May.
I would recommand to enable prefer AMON over SNMP setting.
Pavan
Pavan
If my post address your queries, give kudos and accept as solution!
Contributor I
I dont have any remote access points.
We have DE27808 defect opened for wired device not showing in latest code aswell and this will get address in AMP 8.2.4 along with RAP wired client device.
Pavan
If my post address your query give kudos:)
Pavan
Contributor I
Roger that. Thanks.
With "Preferred AMON" enabled we get AppRF data from the controllers, but the reported number of clients takes a hit.
With "Preferred AMON" disabled we get NO AppRF data, but the number of reported clients are correct.
I've got an open support case regarding this...
Has anyone found a solution to this?
Glen,
May I know the Airwave version, how much client difference you are seeing when you enable prefer AMON setting?
Could you share the support ticket number/
Pavan
Pavan
Hi
The case is HPE Support Case 5320795051
The version is in the case notes. Can’t get to it at the moment on mobile. :(
Glen
