Network Management
AMP 2nd network Device settings not being saved
I am installing AMP 8.2.2 for a customer and he would like to add the 2nd Network device and the NTP servers.  Under AMP Setup \ Network - I enable the 2nd NIC capability enter in the IP information, then enter in the NTP information, hit save and the informatin is not saved.
Any suggestions?
Re: AMP 2nd network Device settings not being saved
Why are you using a second NIC?
The end user has one network for internal access (primary network device) and another network for remote access (secondary device).  and while I have you is the name entered for DNS case sensitive?
