Network Management
AMP 8.2.5 User Guide location?
Under Support > Documentation > Software User & Reference Guides > Airwave > AMP, the folder for 8.2.5 is not located under the expected 8.2.x folder. Any particular reason?
In the Release Notes for 8.2.5, the reader is referred to the 8.2.5 User Guide, however no User Guide appears in the 8.2.5 folder.
Is it squirreled away somewhere else?
Moderator
Re: AMP 8.2.5 User Guide location?
The 8.2.5 folder is up a level to have it stand out a bit.
Documentation is still being worked on.  The 8.2.5 docs haven't all been posted yet as some changes are still being made to the documentation.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
