Network Management
Contributor I
AMP does not show how many APs are UP or DOWN - since 8.2.x
Since we have upgraded to 8.2.x - now we run 8.2.3 - it never showed # of APs UP or DOWN
See screenshot attached. Is tere a way to fix this quickly?
Re: AMP does not show how many APs are UP or DOWN - since 8.2.x
Can you please check the system > performance? To make sure your system resources look good
Get Outlook for iOS
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Contributor I
In my opinion everysthing seems pretty smooth, no process issues..
See screenshots attached
Frequent Contributor I
Is this just the top header in Airwave, or are the APs showing Up also in Folder view or Group view when they are actually down?
Contributor I
Yes just in the Top Header #'s are not shown.
When going to Groups, I see all the Groups, with it's AP's in it..
As well in the folder view see screenshot.
Did you try to go to amp setup > top header and remove and add the devices up?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Contributor I
Yes I tried > rebooted the AMP server as well.. no luck.
See screenshot about UP devices in APs/Devices - shows the 94 devices..
