Network Management
AP configured but showing undefined under 2.4Ghz standard and 5Ghz standard.
Recently I configured a new AP model 125 to replace a faulty one's.  However once it detected in master controller, it shows undefined under the 2.4Ghz and 5Ghz standard and as well no where to be found in the local controller.  It only shows up in the master controller.
Can someone enlighten me on this issue.  And most of all would anything happen in future if it would to remain like this?
Re: AP configured but showing undefined under 2.4Ghz standard and 5Ghz standard.
What version of code is on the controller and what is the country code?
Hi Joseph,
Where can I actually locate that version and country code?
"show version" on the commandline would tell you what version it is running.
"show ap regulatory-domain-profile default" will show you the regulatory domain.
Those are just two guesses, but there could be other things wrong.
