Network Management
Regular Contributor I
AP not showing in Airwave
I had two AP70s that were previously ignored.  I removed them from being ignored and selected both to import settings.  One of the APs came back up with the new info and shows in VisualRF, but the second one doesn't appear in Airwave nor VisualRF.  The AP is on the controller though. I've tried polling the controller, but it still doesn't find it.
Any suggestions?
Aruba
Re: AP not showing in Airwave
AOS 6.1.3.2 will have a fix for bug 54939, where APs whose lan macs end in FE or FF cannot be seen by AirWave. Is it possible that's what's going on here?
