Network Management
Frequent Contributor II
AP signal coverage measurement through Airwave
Can we do AP signal strength measurement through Airwave. I have attached floor plan in Airwave and marked AP location as well.
Thank You...
Re: AP signal coverage measurement through Airwave
Yes.  It requires the flash-based version of VisualRF:
http://www.arubanetworks.com/techdocs/AirWave_8_0_Web_Help/UserGuide.htm#AWUserGuide/Chapter9_VisualRF/Adding_Client_Surveys.htm?Highlight=survey
You can enable the Flash-Based Version of VisualRF here:  http://community.arubanetworks.com/t5/Monitoring-Management-Location/Flash-content-in-Airwave-WebUI-of-Airwave-release-8-x/ta-p/176882
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
