Network Management
APPRF
Dear All,
why our apprf on airwave cant show destination application, not real web name destination like youtube but only just port on listed ?
kindly need your help
Re: APPRF
hi,
Do you have a DNS server on Airwave and have you configured AMON on your controller (assuming you're using one)?
Cheers
James
Re: APPRF
Are you using an instant or a controller ?
Get Outlook for iOS
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Re: APPRF
using controller sir
Re: APPRF
i think I already configure AMON base on link :
https://community.arubanetworks.com/t5/Community-Tribal-Knowledge-Base/Why-you-should-always-enable-AMON-on-your-Aruba-Controller-when/ta-p/72104
need your advice sir to show apprf on my airwave
Re: APPRF
up
