Network Management
Frequent Contributor I
APs/Devices - List going from All APs up to All APs down every few minutes
[ Edited ]
The audit shows good.   However for whatever reason the list of devices keeps changing status from up to down.   The users aren't having any problem connecting.   I'm not seeing any issue when connecting directly to the cluster but I might be looking in the wrong place for issues.
The status keeps changing for some reason.    It only shows the correct number of clients during that time when it shows all APs as up and it is NOT verifying the instant virtual controller.
There are 0 alerts - I have no idea why it shows them as down when they are up.
Looking through my log I see
Instant AP with IP 10.x.x.xPSK based authentication: not contain a valid X-Shared-Secret in request header
Virtual Controller Instant-x:x:x Status changed to 'Virtual Controller authentication failed
Re: APs/Devices - List going from All APs up to All APs down every few minutes
The issue is resolved - changed the APs virtual controller ID.
Having the same issue but cannot find where to change the virtual controller ID.  Can you please post where to do this?  Thank you.
I went to maintenance, made a backup - it downloads the file to your computer.  Then you edit the file in wordpad - just changing the ID and then upload it back.
