The AW-K12-1 is the same as LIC-AW but thats just for school?
If we are quoting an airwave for school for 50 APS we would quote, 50 AW-K12-1 instead of 50 LIC-AW
Just wanted to be sure if its like this
Cheers
Carlos
If the order is for a K-12 school; then yes you can use these SKUs. For AirWave; you'd need quantity 50 of AW-K12-1 and EN1-AW-K12-1 for support.
Thank you !
