Network Management
Contributor I
About AirWave license consumption for multi vendor
I have a question about AirWave license consumption.
How does AirWave count devices and consumption license in case of using Cisco WLC and Aironet APs ?
Are there any functions for the other vendor devices without license consumption ?
Re: About AirWave license consumption for multi vendor
If I understand the question correctly, AirWave should count the WLC and each AP as a 'device'.
Jerrod Howard
Contributor I
Hi Jerrod
Thank you so much for quick response.
Is that mean each AP consume license ?
For example...
I have AW-25 on my AirWave and manage a WLC which controlls 10 lightweight APs.
I can add further 14 devices, right ?
Correct
Tim Cappalli | Aruba Security
Contributor I
Thank you so much !!
I understood it.
Thank you.
Atsushi
