Network Management
Occasional Contributor I
Activate API management
Hello all,
I'm doing a very simple python 3 Script to query the activate inventory.
The problem is that the server is ignoring the body json filters, although URL filters are working.
According to the doc, I wrote the code below.
Json body filter is completely ignored, and if I omit the URL filter the response is all devices in the directory
Everything is working but the Json body Mac device filter.
Could you give a hand?
Thank you very much
import os, sys, re, argparse
import urllib.parse
import getpass
import urllib.request
import urllib
import json
import traceback
import pprint
line="https://activate.arubanetworks.com"
string_oauth={"credential_0" : "XXXXX","credential_1": "XXXXXX"}
jsonbody_url=urllib.parse.urlencode(string_oauth)
jsonbody_bytes = jsonbody_url.encode("utf-8")
print('Autenticando en : ',line)
req=urllib.request.Request(url=line+"/LOGIN",data=jsonbody_bytes,method='POST')
#construimos y enviamos consulta http
try:
f=urllib.request.urlopen(req)
except urllib.error.HTTPError as e:
if hasattr(e, 'code'):
print('ERROR HTTP ', e.code)
if hasattr(e, 'detail'):
print('Reason: ', e.detail)
print("autenticación fallida:Cerrando Aplicacion")
sys.exit(e.code)
else:
print("solicitud aprobada")
cookie=f.getheader('Set-Cookie')
f.read()
string_query={"devices" : "34:FC:B9:CE:12:E4"}
json_alta_guest=json.dumps(string_query)
json_alta_guest_bytes=json_alta_guest.encode('utf-8')
req=urllib.request.Request(line+"/api/ext/inventory.json?action=query&deviceFilter=basicData&addDate=06-15-2017",data=json_alta_guest_bytes,headers={"Cookie" : cookie,"Content-Type": "Application/json", "charset":"UTF-8",
"Connection": "Keep-Alive"},method='POST')
try:
var=e.read().decode("utf-8")
print("HTTP "+str(e.code)+" "+"\n")
else:
print(f.headers)
data=json.loads(f.read().decode('utf-8'))
print(data)
print("succesfull")
Re: Activate API management
Try this Curl command from any ofyour linux server it will pull all the whitelist devices from activate.
#curl -3 -b Activate-cookie.txt 'https://activate.arubanetworks.com/api/ext/inventory.json?action=whitelist'
Pavan
Pavan
If my post address your queries, give kudos and accept as solution!
Hello Pavan,
Curl is not an option in my enviroment, but I tried the url on my script and worked. The problem is that we have also controllers and switches we want to query about.
I'm interested in getting all device of data matching a certain mac_address, or, if possible, a serial number, do you know any url request which allows to do that?
Would like to solve the json body filter anyway, anybody has more ideas?
from where you want to pull the controller and switch inventory details Activate or Airwave?
Pavan
Pavan
<Hello Pavan
Activate
Pass the MAC as form-urlencoded:
{ "devices" : [ "AA:BB:CC:11:22:33" ] }
Tim Cappalli | Aruba Security
I have attached Aruba Activate guide , Check Inventory APIs from page 36 for more details.
Pavan
If my post addresses your query give kudos:)
Pavan
Hello TIm,
I already tried:
string_query={"devices" : [ "34:FC:B9:CE:14:7E"]}
jsonbody_url=urllib.parse.urlencode(string_query)
json_alta_guest_bytes=jsonbody_url.encode("utf-8")
req=urllib.request.Request(line+"/api/ext/inventory.json?action=query&deviceFilter=basicData&addDate=06-16-2017",data=json_alta_guest_bytes,headers={"Cookie" : cookie,
"Content-Type": "application/x-www-form-urlencoded", "charset":"UTF-8","Content-length":len(json_alta_guest_bytes),
and no effect. I left the other version because is the same method I use to manage ClearPass Json API, so that's the reason I think the code is correct.
I tried with an APi that only accepts jsond body filters(folder update API):
string_query={"devices" : [{"mac" : "20:4C:03:04:31:80",
"deviceName" : "nombre de prueba",
"folderName": "XXXXX"
#activate.arubanetworks.com/api/ext/inventory.json?action=update.
#string_query={"devices" : [ "34:FC:B9:CE:14:7E"]}
#json_alta_guest=json.dumps(string_query)
json_alta_guest=urllib.parse.urlencode(string_query)
datos=json_alta_guest.encode('utf-8')
req=urllib.request.Request(line+"/api/ext/inventory.json?action=update",data=datos,headers={"Cookie" : cookie,
"charset":"UTF-8","Content-length":len(datos),"Host": "activate.arubanetworks.com",
"Connection": "keep-alive"},method='POST')
try:
and this is the server reponse:
errors': [{'key': 'json', 'errMessage': 'json POST parameter must be supplied for update action}]
Do you have any way to check what's the error detected in the server to return such error message?
As I said, the way I build the request is the same I use for Clearpass guest API, so I think the problem is not the request I'm sending...maybe a header missing?
Hello Pavan,
I already read the doc before writing the code, that's the reason I posted the case.
thank you all for the support
Hello TIm,
I also tried Urlenconding the data before sending with no luck. The code I posted is pretty much the same I use to manage the Clearpass API, so I think the code is ok. I could have overlook something though.
In case it helps, I tried with an APi that only accepts json body filters (folder update API)
"folderName": "XXXX"}]}
"Connection": "keep-alive","Accept-Encoding":"deflate, br","Origin":"https://activate.arubanetworks.com",
"Referer":"https://activate.arubanetworks.com/registration/","Accept-Language":"es-ES,es;q=0.8"},method='POST')
try:
and this is the server response:
-----errors': [{'key': 'json', 'errMessage': 'json POST parameter must be supplied for update action.'}]}
Do you have any way to check what's the reason the server returns this error?
I tried with the other version too:
"Referer":"https://activate.arubanetworks.com/registration/","Accept-Language":"es-ES,es;q=0.8","Accept":"*/*"},method='POST')
and same server response
Thank you very much
