Network Management
Occasional Contributor I
Add ap on airwave
From the Airwave I try to add a new AP of mark Aruba 215 from the access point the community and the servant that SNMP points has been created nevertheless from Airwave it indicates the following thing: Status: Down (SNMP get failed)
rzz
Contributor II
Re: Add ap on airwave
since it is a aruba access point, is there any reason not to use ammon instead but SNMP?
Secondly do you have sufficient LIC-AW?
Instant APs do not use AMON.  They use https post between the IAP and Airwave:
  Instant APs should be added to Airwave throught the Instant VC gui like below.  They should not be added through the Airwave device add dialog.  They are also not monitored through airwave by setting an SNMP read string on the IAP.
For this and more information, please see the Instant Validated Reference Design Guide here:
https://community.arubanetworks.com/aruba/attachments/aruba/Aruba-VRDs/76/2/Aruba_Instant_VRD_2016.pdf
I currently have 170 devices from the 200 of the license, I do not know what the error is
Hi Joseph
The shared key is the same with which I enter the platform or is one that I generate and, if so, from where it is made. Regarding the activation option of aruba (activate.arubanetworks.com) in which it benefits, is it important to add the APs to the Airwave?
Shared key can be anything. It is given by the user when you want to add IAP to Airwave. It acts as a bridge between the IAP Airwave communication(similar to community string for snmp)
When you add the IAP to Airwave for the first time you can give anything as the shared key. Once you have the Airwave IP, Organisation name and shared key given on IAP under settings, the particular VC will appear in the new device list on Airwave and also a group and folder will be automatically created on Airwave based on the organisation name you have given. Once the VC appears in the new devices list you can move it to the respective group and folder.
Vishnu
If my post helped you, don't forget to give kudos ;)
