Network Management
Frequent Contributor II
Adding devices to Airwave
Can someone tell me how to add devices to Airwave?
I doesn't seem to want to find some of my Aruba controllers.
I've added the proper subnet for scanning, but still no luck.
Is there a way to manually add a single device?
Tony
Re: Adding devices to Airwave
Tim Cappalli | Aruba Security
How did I miss that???
Thank you!
Contributor I
One way is to use SNMP. To do this your SNMP credentials much be matching between controller and Airwave.
MCSE +Security,
IBM Certified Advanced Systems Administrator
ACMP, ACCP
Is there an API to add/remove devices from AirWave?
Type https://<ip address of airwave server>/api to see what is supported and how.
Thanks Colin,
Where can I find details and examples using the API? I've looked through the Aruba Documentation files, but dont' see anything related to the API.
Matt
The API documentation is on the Airwave Server:
https://<ip adddress of airwave>/api
