Network Management
Adding secondary master Airwave!
  • 1.  Adding secondary master Airwave!
    Posted Dec 13, 2013 08:45 AM
    Hello
    Im trying to add the secondary master to airwave without any luck...
    I got the master on the airwave... i tried adding the second master in standby to the airwave but i cannot do it, as is not working.
    The config is just the same... with SNMP3
    Now also i notice that i cannot delete the snmp users for some reason
    (WC_Master_2) (config) #show snmp user-table
    SNMP USER TABLE
    USER          AUTHPROTOCOL  PRIVACYPROTOCOL  FLAGS
     user1    SHA           AES
     user2   SHA           AES
    (WC_Master_2) (config) #no snmp-server user user1
    Error: Snmp User cannot be deleted
    Any help :)
    Cheers
    Carlos
  • 2.  RE: Adding secondary master Airwave!
    Posted Dec 13, 2013 11:22 AM
    Did AirWave not discover the secondary master and put it in 'new devices'?
    What version of firmware is the controller running?
  • 3.  RE: Adding secondary master Airwave!
    Posted Jan 05, 2014 09:41 PM
    Hello rob
    the verion of the controller is 6.2.1.4
    the version of the airwave is 7.7.4
    i get snmp get failed, and i got it configured exctly as the controller that working
    Cheers
    Carlos
  • 4.  RE: Adding secondary master Airwave!
    Posted Jan 06, 2014 03:01 PM
    From the AirWave CLI, do SNMP walks to the standby controller work?  Double check that the working credentails are the same that show up in the standby controller's manage page (in AMP).
