Network Management
Air Wave Coply
Dear Team,
Does below requirement  comply with Airwave.
NMS should be able to monitor, manage, and deploy new network devices and get them up and running in a very short time.
Easy to use and access via a Web Browser, NMS should be a simple, with an easy-to- learn graphical interface.
Create, delete or modify VLANs across one or multiple devices
Should provide security access to parameters such as CLI, web, SNMP, RADIUS access and access policies
Inventory for upgrading devices, backing up configuration files, archiving, synchronization and restoring files
Should be able to compare configuration files
NMS should provide Web-based display of products from a single location, giving network managers a complete view of products without physically checking each device.
Should  provide  continuously  update  physical  view  of  switches  in  the network
Should   support   scheduler   for   configuration   of    tasks   such   as uploading /downloading files, backup etc.
Should be able to support at least 200 network devices.
Moderator
Re: Air Wave Coply
Quick answer is yes to all of the above.
Longer answer would be that these items fall into the following features:
ZTP, UI, Device Config Mgmt, IP tables, Inventory Report, Config Mistmatch report, Device Monitoring pages, Topology, Device Config Mgmt (Scheduling), and the License key.  With some overlap with other features as there's some redundant features that provide a different look at the network depending on troubleshooting path.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
