Network Management
Occasional Contributor I
AirWave 8.2.3 System Requirements
can someone point me in the right direction.
I need official document about system requirements for AirWave on Hyper-V enviroment. In the AirWave 8.2 Installation Guide Aruba has tested Hyper-V on Wind. Server 2000 R2.? I think that this is type failure but i need official document that i can show to my customer.
Also it would be good to have official document for system requirements (hdd, CPU, RAM) when you are doing installation on virtual enviroment and not something like: "Aruba recommends a 20% increase buffer for virtual environments."
Thanks.
Re: AirWave 8.2.3 System Requirements
Hi Tom,
Please check Airwave server sizing guide
https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/EntryId/23720/Default.aspx
Airwave resources allocation varies based on number of factores, please check sizing guide for detail informaiton.
Pavan
Pavan
If my post address your queries, give kudos and accept as solution!
Hi Pavan,
that was quick. I did check all these documents that is why i am posting here. :)
Hi Tim,
We need to add extra 20% more resources in VM envorinement. If you are planning to monitor around 1500 deivces allocate below recommanded  resourecs with 20% more.
In VM, allocate
8 CPU cores
55GB RAM
Storege capacity varies depend on historical retention settings,if you have high value allocate recommended disk space.
Currently we do not have sperate document related to sizing guide for virutal envoirment.
Pavan
Pavan
Hi Pavan,
i have already gone trough that document. I have found this calculator, that is much better then that document: https://ase.arubanetworks.com/solutions/id/77
Ok now at least i have that coverd. Can you help me with Wind. Server. In the install document it there is Windows Server 2000 R2!? Should this be 2008 or 2012 ?
I believe it is tested on 2008R2 but I am not sure exactly, will check and get back to you on this.
Pavan
Pavan
Hi Tom,
It is tested on 2012.
Pavan
Pavan
Thanks Pavan.
It would be good if you can push this to be corrected in the official document.
Sure, will report to the concern team.
Pavan
Pavan
