Network Management
Contributor II
Re: AirWave 8.2.4 NO CLI
We often change the graphics on the login page so that is another reason we would need ssh access.
Occasional Contributor I
The best solution for all is to generate a SSH access with OpenPGP like the new AWSupport Access.
With OpenPGP there are no security reasons to terminate the CLI
Another feature request/CLI function is MIB Walk to confirm SNMP is working or if interfaces or values can be accessed from controller IP.
I'd prefer to have a full shell available for when I need it. And so far we've needed it. We couldn't have deployed AMP 8.2.3.1 without a root shell, because of the need to resize the underlying volumes and filesystem.
I wish I had know that this was the direction Aruba was headed with their products, before we bought them.
MIB Walks are getting added to the AMPCLI in a future version.
Jerrod Howard
Sr. Techical Marketing Engineer
Re-scaling the disk is usually handled via creating of a new AMP deployment with the proper disk settings and then restoring a nightly backup on to the new platform. While some can properly re-partition and format, most fail and leades to big support efforts and usually loss of data.
Jerrod Howard
Moderator
Let me see if I can help address some of these comments.  I'm also fwding to PLM so that they can review:
@jeff.g.kier - snmpwalks = US16804
@alow - change graphics - need more info, which images are you changing?  I've filed US16805, but need more info on the specifics that you're changing for PLM to make an educated decision.
@HLavender -
cert generation = US16631 (w/ CSR), US14594 (just cert generation, no CSR)
there's no SCPing of files between 2 AMPs.  If you have Failover, it will still get the backups of the monitored AMPs via http/https.
@Michael_Clarke - static route = US16801
@gilmorrr -
backups -> see the backup menu, there's a 'set destination' that will auto SCP backups to a destination.  If you already had a script performing this in a cronjob, that cronjob will continue to run.  Edits to cronjob will be mitigated in support cases.
db access -> if you can expand on the tables you utilize the most, then we can make sure the APIs get expanded to cover those tables
mass import = US16806
@Chris F
ifconfig / bonded interfaces = US16625
@Sascha Becht
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
Contributor II
Rob
We often change the following on some of our AMP servers.
/var/www/html/images/theme/airwave/title.png
/var/www/noauth/theme/dev/login-logo.png
/var/www/noauth/theme/airwave/login-logo.png
We use have been using these appliances in a manged services enviroment for a number of years and have given cusotmers access to the AMP appliances to run reports etc. So we have changed some of the images to reflect the platforms function.
Its a small change but they need to be updated every time we patch the appliances or deploy a new one.
thanks
Andy
Moderator
Got it, added the details into the feature request.  PLM are planning to review the items filed this week.
Rob Gin
Jerrod,
I don't follow. What is deploying with proper disk settings? How would I deploy the OVA a second time and get different results?
