Network Management
Contributor I
AirWave 8.2.4 and vmtools
With the new ampcli, it is impossible to install/upgrade vmtools...
How can install vmtools ?
one of solution, it will be to use open-vm-tools but airwave use a (very) old release of CentOS...
Need to use CentOS 7.0, no plan to update ?
Re: AirWave 8.2.4 and vmtools
That needs to be handled in a support case with TAC. They will generate support connection, and can help you with the VM tools part.
Currently Centos 7 is not supported.
Vishnu
If my post helped you, don't forget to give kudos ;)
Contributor I
There is no plan to be more easy ? because always ask TAC for install/upgrade vmtools
No plan to enhance ?
For current version please involve support so that they can help you with this.
This is already been raised as a feature request. Please refer to the below thread for details on the feature requests.
http://community.arubanetworks.com/t5/Network-Management/AirWave-8-2-4-NO-CLI/m-p/298504
Vishnu
