Network Management
AirWave 8.2.5 update issue
  • 1.  AirWave 8.2.5 update issue
    Posted Oct 12, 2017 08:29 AM
    I currently running 8.2.4.1 of AirWave. I noticed that 8.2.5 was released. I have tried to upgrade through the CLI menu system. When it comes to where to download from I have tried from the Aruba Support and HPE support. Both of the downloads say to check the site  to see if it is there because it could not find it. I have logged into the Aruba Support site and see it there. Is there a way to do the update through the web GUI?
  • 2.  RE: AirWave 8.2.5 update issue
    Posted Oct 12, 2017 09:02 AM
    Apperently the update guide is wrong.
    Had the same issue.
    Instead of typing 825 in the update process, try 8.2.5 or 8.2.5.0 (cant remember which worked)
  • 3.  RE: AirWave 8.2.5 update issue
    Posted Oct 12, 2017 09:21 AM
    We ran into the same issue when upgrading to 8.2.5 yesterday.  I had to manually download the file and transfer the file using SCP.  Hopefully HPE Aruba can correct this so others will have an easier time of upgrading to 8.2.5.
  • 4.  RE: AirWave 8.2.5 update issue
    Posted Oct 12, 2017 09:34 AM
    Hello!
    Alternatively you can download the upgrade package manually upload it to the amp from an scp server (i used a qnap nas).
    1. Choose "Upload File" in the menu.
    2. Use the sytax: admin@x.x.x.x:/share/AMP-8.2.5-x86_64-cvs.tar.gz
    3. Hit enter, and type in the password at prompt.
    As next step you can Upgrade the amp choosing "7 Upgrade".
    Type in 8.2.5.
    Works for me!
    Cheers
  • 5.  RE: AirWave 8.2.5 update issue
    Posted Oct 12, 2017 09:46 AM
    I was going to try this but we have no SCP server. I cannot instal a SCP server.
  • 6.  RE: AirWave 8.2.5 update issue
    Posted Nov 24, 2017 04:55 PM
    Hi Matthias,
    I have to upgrade to version 8.2.5 next week, where can I get that console menu from?
    @mom wrote:
    Hello!
    Type in 8.2.5.
    Works for me!
    Cheers
    Julián
  • 7.  RE: AirWave 8.2.5 update issue
    Posted Nov 26, 2017 03:38 AM
    Hello Julián!
    SSH to your AMP, login as ampadmin.
  • 8.  RE: AirWave 8.2.5 update issue
    Posted Nov 27, 2017 02:22 PM
    Hi Matthias,
    I am upgrading from AirWave 8.2.3.1, so following the steps of in AirWave 8.2.5 Release Notes > Upgrade from AirWave 8.2.3.1 I will not see that menu and I will to upgrade with the command "start_amp_upgrade -v 8.2.5". AirWave 8.2.3.1 doesn't have that menu. Am I right?
    Julián
  • 9.  RE: AirWave 8.2.5 update issue
    Posted Nov 27, 2017 02:27 PM
    8.2.5.1 will be released soon.  (it's already on the Aruba Support Portal, it'll appear in MNP in about 2 weeks).
    The release notes goes through both upgrade scenarios.
    For upgrades prior to 8.2.4:
    Upgrade from AirWave 8.2.3.1 or Earlier Versions
    If you upgrade from AirWave 8.2.3.1 or earlier, you will no longer have root user access to the Linux shell after
    the upgrade to AirWave 8.2.5.1, and your system will be converted to use the new AMP CLI. For information
    about using the AMP CLI, see the AirWave 8.2.5.1 User Guide.
    Follow these steps to upgrade from AirWave 8.2.3.1 or earlier:
    1. Log in to the AirWave server as the root user.
    2. Run the upgrade utility:
    #start_amp_upgrade -v 8.2.5.1
    The upgrade utility looks for the local upgrade package.
    After the download completes, the following message appears while the software compiles:
    Validating the upgrade package...
    Upgrade package is OK.
    Using upgrade script extracted from local package.
    Upgrade package found in local cache.
    If the software is not available, manually download the software and then perform this step again.
    3. After the AMP services restart, you will see the following message:
    Setting up secure accounts...
    Setting admin user name...
    Admin Username (default 'ampadmin'):
    Admin user is admpadmin
    Done
    Setting admin password...
    Admin Password:
    Verify Password:
    Done
    Done
    Removing alias for less...
    Done
    AMPCLI Setup completed
    Enter the new ampadmin password. If you don't enter a user name, AirWave uses the default "ampadmin".
    4. After setting the password, you will see the following message:
    Your system has been converted to use AMPCLI. You may now
    log in as ampadmin. If you lose the password for ampadmin you
    may log in as amprecovery (password recovery) on the console to reset
    the ampadmin password
    5. Finally, remove any OS user accounts to prevent unauthorized access.
  • 10.  RE: AirWave 8.2.5 update issue
    Posted Nov 27, 2017 03:34 PM
    Hi!
    As rob wrote ... AMPCLI started with 8.2.4.
    Use rob's manual above.
  • 11.  RE: AirWave 8.2.5 update issue
    Posted Oct 12, 2017 09:48 AM
    I have tried 525, 8.2.5 and 8.2.5.0 with no success.
  • 12.  RE: AirWave 8.2.5 update issue
    Posted Oct 12, 2017 09:51 AM
    Do you have no linux based NAS box arround?
    Like qnap, synology....?
  • 13.  RE: AirWave 8.2.5 update issue
    Posted Oct 12, 2017 09:53 AM
    We are a Windows only shop with a few exceptions (AirWave,...)
  • 14.  RE: AirWave 8.2.5 update issue
    Posted Oct 12, 2017 09:57 AM
  • 15.  RE: AirWave 8.2.5 update issue
    Posted Oct 12, 2017 10:08 AM
    I cannot install any software on any computers. Computers are locked down because this is a hospital.
  • 16.  RE: AirWave 8.2.5 update issue
    Posted Oct 12, 2017 10:20 AM
    Than I would contact your Microsoft client admin...
    Good luck!
  • 17.  RE: AirWave 8.2.5 update issue
    Posted Oct 12, 2017 10:38 AM
    They said it was not an approved software and will not be installed. Why can't Aruba fix the update issue? Or at least give another way of uploading the downloaded file.
  • 18.  RE: AirWave 8.2.5 update issue
    Posted Oct 12, 2017 07:00 PM
    We are looking into additional means of upload.  In the meantime, you can also open a case with TAC - they can create the support user account and use that account to upload the file from a SFTP source.
  • 19.  RE: AirWave 8.2.5 update issue
    Posted Oct 19, 2017 10:08 PM
    Could you try the CLI upgrade once again using your Aruba credentials if you havent upgraded? I believe it should work now. Tested in lab and it works. There was some issue for upgrade with Aruba credentials and its fixed now.
