Network Management
Frequent Contributor I
AirWave / AMP 8.2.0 VisualRF is missing clients
Hi All,
I just upgraded to AirWave 8.2. Its sweet!
One issue that I've noticed so far. All of my clients that I used to see on VisualRF do no appear. Under properties of the floor it shows "Clients: 0" but I have over 50 clients. AirWave sees the clients if I go to Clients tab but just doesnt place them on VRF. APs on VRF are showing green and show other data like channel utilization, rx/tx, access, power, etc.
I've tried different browsers/workstations to elimate that as an issue. Any ideas?
N
MVP
Re: AirWave / AMP 8.2.0 VisualRF is missing clients
How much time did you give Airwave after the upgrade? VisualRF can take some time to rebuild the location database for the clients.
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
I just logged in again for the first time since Friday. Still no data and clients show 0 on properties tab of the floor that I am looking at.
MVP
You can try this URL:
https://[your airwave IP or fqdn]/visualrf/poll_aps_now.xml
It forces a re-poll of all APs for everything, and usually fixes any missing clients/heatmap events in my installation. If that doesn't help, I'd get a case open with TAC.
--Matthew
That didn't work.
I opened up a TAC case. Apparently they are seeing this in a few places. May be a possible bug. They took some data/logs and are reviewing. Will update as I know more.
N
Hi! I also have this issue. Any news from your support ticket?
thanks!
/Mikael
Same Issue here!
With Version 8.2.0.1
They pulled backups and are rebuilding in lab environment. They have seen this multiple places. Open a ticket so they can validate it is the same problem.
N
Sent from Outlook Mobile
Everyone who is replying, please open a TAC case, so that your problem can be looked at and addressed.  It is possible all the issues are different, so if you rely on others to report problems that seem like yours, your issue might not be fixed.
TAC has filed a defect for my issue.
