Network Management
AirWave Appliance *Enterprise* Notification
For those who've received AirWave Appliances **Enterprise** level (Dell r620):
The NIC is still good and the server is not defective.
AMPs preinstalled with version 7.5.6 have ethernet ports that are not in order.  The ordering of the interfaces out of the box will be:
2  3  0  1
-This is the default ordering for a new Dell r620 out of the box.
The easiest resolution is to reinstall the appliance with the AMP 7.6 ISO.  This will repair the ordering to:
1  2  3  4
-AMP 7.5.7 and after have a built in script that corrects the ethernet interface ordering to match the bus order.
Again, this is only for the Enterprise level appliances on Dell r620 hardware.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
