Network Management
Contributor II
AirWave License for Virtual Appliance
Hello, just for clarification. Are there specific licenses required for the AirWave VM?
If 300 Aruba LIC-ENT (JW471AAE) are purchased and 300 support licenses (H2XW3E - Aruba 1Y FC 24x7 License Cn Bundle SVC for JW471AAE), are there any other required licenses.
This will be a single AirWave instance...no failover/Glass/Clarity/etc...
Thanks!
Moderator
Re: AirWave License for Virtual Appliance
no additional licenses needed.  the 300 device license is all that you'll need.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
