Network Management
AirWave Licensing
Hi all!
Maybe it will sound primitive, but still i just can't figure out AW linsening...
For example:
My client wants AirWave for 25 device's but with secondary AW server (in case of primery server to fail)
How must i calculate his license?
Should it look like that:
Base system: AW-25 + AW-25
Support: SA3-AW-25 + SA3-AW-25    ?
Or instead of using AW-25 lincense for secondary server i can choose AW-25-FR ? Will it work like a reserved server?
And how to add lincense for a 1 or 2 devices, in case if that client will "expand" to 27 devices? Just add two AW-EXP1-50 ?
Sorry for my bad english.
Regular Contributor I
Re: AirWave Licensing
For 25 devices on one server with failover capability for 25 devices on another server, you'd buy 1 x AW-25 and 1 x AW-25-FR (the failover version). Then you'd add SAx-AW-25 and AWx-AW-25-FR (where x is the number of years).
The Failover server works by copying the nightly backup from the primary and taking over for it if there's a failure.
If the client wanted to expand to any number between 26-50, it's necessary to purchase another AW-25 (or to buy AW-50 in the first place). However, once 50 devices are under management, you can purchase devices one at a time with AW-EXP1-50 (one device at the same price/device you pay for 50 devices). AW-EXF1-50 is the Failover part.
Thank you very much!
PS: Can i find somewhere something like "Aruba licensing guide"?
On our public website, I see this doc:, which does have a section on licensing.
