Network Management
Occasional Contributor I
AirWave MIBs
I was looking for MIB guide for AirWave but with no luck.
AirWave is sending specific to him OIDs i.e.. 1.3.6.1.4.1.12028.. and I would like to get some more details about them.
Does anyone came across that guide ?
Re: AirWave MIBs
Are you seeing this in the trap logs?  Are they coming in from devices or is Airwave itself sending them?
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
Re: AirWave MIBs
We see it coming in to our trap server.
And they come with source IP of AirWave.
For example 1.3.6.1.4.1.12028.4.xxx is specific to Instant AP.
Moderator
Re: AirWave MIBs
This request would get better traction by opening a support case.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
Re: AirWave MIBs
Rob is correct.
Can you post a specific trap you are getting and maybe we can help.
For example 1.3.6.1.4.1.12028.4.15 is the following trap
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
Re: AirWave MIBs
I was hoping you can direct me to the file you are using in the mib browser from the screenshot.
There are few traps we are getting plus it would be nice to have it for future reference.
Do I need to open a case to get it ?
Moderator
Re: AirWave MIBs
@pmonardo uses a 3rd party mib crawler tool against the aruba mibs.  If you don't want to use a 3rd party app, you could just take the oid and run it against the internal translation scripts on the AMP like so:
[root@amp mibs]# oidtranslate 1.3.6.1.4.1.12028.4.15
AWAMP-MIB::awampEvent
[root@amp mibs]# oidinfo 1.3.6.1.4.1.12028.4.15
awampEvent OBJECT-TYPE
-- FROM AWAMP-MIB
::= { iso(1) org(3) dod(6) internet(1) private(4) enterprises(1) airwave(12028) awamp(4) 15 }
Some of the mibs may be harder to define from just viewing in the mibs, which is why I suggested checking with support.
Rob Gin
