Network Management
Trusted Contributor I
AirWave RAPIDS SSID rule mismatches
Im using a RAPIDS rule to detect our SSIDs on equipment not belonging to us.
pretty simple setup:
  Device has been detected wirelessly: Yes
  SSID: Matches
  GUEST
  INTERNET
  DB_INTERNET
Only i see hits which don't make sense to me, for example:
  Intern-FPCP-01
  GUEST_something
is assume the GUEST_something is het due to GUEST being in the list. but the Intern-... is weird. there is another one that makes even less sense. can i at least make sure that it only compares full names against each other?
Re: AirWave RAPIDS SSID rule mismatches
As far as I know it would match if you used a wildcard * but IMO it should not be an exact match at this point. From Airwave -> Matching is case-insensitive, and ignores whitespace and non-alphanumeric characters.
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
yeah i read that also, so anyone with experience or is this worth creating a ticket on?
after looking around somewhat more i noticed these were some quite old entries, some over 2 years old. i cleaned up the old one and now there is just one match which is on InterNet which makes sense. so it might just be a fluke.
ya ive noticed that you need to spend some time with RAPIDS after setting it up, might take a week or two to clean things out...
ACDX #420 | ACCA
