Network Management
AirWave Thresholds
We have just installed AirWave to manage our Aruba Wireless solution which we are currently in the process of deploying across our campus.
I have noticed within "Clarity" and some of the diagnostics pages for the Access Points that we have 'Issues' highlighted due to a threshold being breached. For instance 'Number of clients on a radio' is set to have a threshold of 10 which seems rather low to me? Has anybody made changes to the default thresholds?
Thanks.
Moderator
Re: AirWave Thresholds
The thresholds will vary depending on the environment.  The current thresholds are tailored toward a minimum suggestion.  If you do update the thresholds, we'd love to hear how you've fine tuned it for your environment, and the type of deployment.  There's a feature request that's being tracked to provide threshold suites based on different customer environments (i.e. office, education, higher ed, hospital, airport, etc), but it's based on getting feedback from the field.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
