Network Management
AirWave Upgrade Questions
Hello, everyone.
I have a question about AirWave OS upgrade.
Currently using version 8.2.4.1.
I want to upgrade to 8.2.6.1, can I upgrade at once without going through the intermediate version?
If I have to go throught the intermediate version, which version should I go through?
Re: AirWave Upgrade Questions
Yes, you can directly upgrade to 8.2.6.1 from 8.2.4.1.
Vishnu
If my post helped you, don't forget to give kudos ;)
Frequent Contributor I
In case of AirWave no internet connection, How to process this?
In version 8.2.4 and newer, I cannot access as root to do anything.
Please advise.
Thank you,
Ratchapas S.
Thailand ^_^
You can download the image from the support site and manually upload to the Airwave server via the cli.
ACCP, ACCX #817, ACMP, ACMX #294
Direct SCP access is not allowed in 8.2.4. So, you will need to upload it to another server which has SCP access.
AirWave Management Platform 8.2.4 on localhost.localdomain
  1  Upload File
  2  Download File
  3  Delete File
  4  Backup
  5  Restore
  6  Support
  7  Upgrade
  8  Advanced
  9  Security
10  Custom Commands
  q  >> Quit
Your choice: 1
Running Upload File
SCP Source (user@host:path): root@10.xx.xxx.77:/tmp/<upgradepackage>
Password:
Uploading root@10.17.164.60:/tmp/<upgrade package>
Once upload done, click on option 7
Pavan
If my post address your queries, give kudos and accept as solution!
