Network Management
Frequent Contributor I
AirWave VM Ethernet0 to virtual network "VMnet0"
i have loaded the AirWave Vm 7.7.4 and started with VM Workstation 9.0 for Testing. I tried to Bridge the Networkadapter, but i get the Message  ### Could not connect Ethernet0 to virtual network "VMnet0" ###
Any Idea?
Best Regards
