Network Management
Frequent Contributor I
AirWave VisualRF and Meraki
Does anyone know if Meraki will work with AirWave / VisualRF for heat mapping? I have a customer that has dead spots but doesnt want to commit to new infrastructure yet. Not a Meraki expert.
-N
Re: AirWave VisualRF and Meraki
Hi
We does not have support for Cisco Meraki but you could try add and check the status, in Airwave will could try add the device type as universal.
Attached supported guide for your reference.
Pavan
Pavan
If my post address your queries, give kudos and accept as solution!
Has anyone else had success with this (universal device approach) ?
I dont remember exactly but you could try, Airwave will provide minimum monitoring support for universal devices but related to heatmaps in VisualRF the device entry should be present in catalog_repository file, I dont see any details of meraki in file.
Pavan
If my post addresses your query give kudos:)
Pavan
