Network Management
Frequent Contributor I
AirWave and AP-303H
We just started installing the AP-303H abd AP-315s throughout our residence halls. I've noticed that the AP-303H show up as model AP-50 and no heatmap in Visual RF. The AP-315 show up fine and with a heapmap. Do we need an upgrade? We are running AirWave 8.2.3
Re: AirWave and AP-303H
HI,
Supported is added in 8.2.4
Pavan
if my post addresses your query give kudos:)
Pavan
If my post address your queries, give kudos and accept as solution!
does that mean they aren't supported in 8.2.3?
*Jon Hutchinson*
*8B Packer Ave rm 185*
*Lehigh University(610)758-5099*
Need to upgrade the server to 8.2.4 to get device support.
Pavan
Pavan
