Network Management
AirWave and nested groups
I'm working through setting up and importing devices into AirWave, and I'm getting ready to import some APs into it.  Our consultant created a couple of them, but I can't remember the process to create a new sub-group under the Access Point group, and can't find anything in the documentation.  Can someone help refresh my memory?
thanks all
SJ
Scott A. Jones, CCVP
Network Architect
Orrick, Herrington and Sutcliffe LLP
Re: AirWave and nested groups
Groups are for if you want to setup configuration for your controllers/devices in Airwave and push them to devices.  You cannot create sub-groups.
You probably want Folders, which CAN be hierarchical.  When you enter a folder, you should see the NEW FOLDER link in the lower left hand corner of the page.
Colin Joseph
Aruba Customer Engineering
Ah--that makes more sense!  Still trying to get a handle on terminology.
Thanks again!
Network Architect
Contributor I
I know this is old, but in case someone else runs across this. . You can have nested groups. You can only have a maximum of two levels, though.
